Root [MOD] CM10 Framework Sound Steps
Angablade
DISCLAIMER: I AM NOT RESPONSIBLE IF YOU BRICK / RUIN YOUR PHONE IN ANY WAY.
BASIC COMPUTER SKILLS ARE REQUIRED FOR THIS!
IF YOU DON'T KNOW WHAT ROOT IS, YOU PROBABLY DON'T NEED IT OR THIS
PROCEED WITH CAUTION!
!.SERIOUSLY.!
<<INTRO/ABOUT>>
This mod revises the volume steps and allows for a more precise control over the volume of anything on your device. You can go from quite quiet to Ludicrous Loud! While being able to choose depending on what you are listening to.
I have compiled a list of framework files I have modded for various rom choices for our device.
Enjoy the tuneage!
<<THANKS/SUPPORT>>
No thanks to me needed.
Thank BobzHome.
Thank Playfulgod.
Thank andriodadmirer.
Thank TheDemon
Thank aboatright
Thank anyone else I missed.
<<INSTRUCTIONS>>
Just flash the zip according to your rom in cm, and you are all done.
<<DOWNLOADS>>
JellyBam
Version: 1.1
Mirror #1 : Download
Mirror #2 :*Download
LiquidSmooth
Version: 08/09
Paranoid Android
Version: 06/08
Mirror #2 : Download
BobZHome CM 10 Vanilla
Version: 05/21
Playfulgod CM 10 Vanilla
Version: 08/17
Dirty Unicorn
Version: 08/23
Touchwiz
Version: 08/19
<?reserved?>
Update Log:
  • 08/29/13
    1. Added Second Mirror
  • 08/25/13
    1. Edited Thread
    2. Revised OP
    3. Added More Build Choices (Dirty Unicorn, Touchwiz)
  • 08/18/13
    1. Edited Thread
    2. Added More Build Choices (PG's Vanilla build, paranoid android, liquid smooth, jellybam)
  • 08/16/13
    1. Post thread Initally
This changes the volume steps built into the phone from 7 or 10 (e.g. pressing volume up makes volume go from 10% to 20%) to a whopping 35. So you can dial in on the perfect volume for the occasion. Works good with the call volume fix. Really really good. Yumm.......
If you're on one of johnnyl1111's ports don't flash this... The framework on the ports is different than the framework for cm10.. OBVIOUSLY, but just a heads up..
Once I get home from work tonight at 10pm, I will do the other framework mods for avatar, and liquidsmooth.
Can someone test these all for me? I can only test what I use.
I'm using a skeletal build of bobz's merged with hk's. Built from source.
How is this working for everyone? I got downloads but not many people saying anything. I believe this also helps with the volume leveling on all Roms I have tested.
