Hi,
I just did this mod for my Xperia X8 running CM7-J005 ROM and it works!
So if you guys want IEEE 802.11N on your Xperia X8 hit the link.
[MOD] Faster WIFI for X8 - N standard enabling <-- here
DISCLAIMER: Please use the info below at your own risk with no warranty of any kind.
Method:
1. <Launch><Root Explorer>
2. go to /system/etc/firmaware <check> that you have the following files:
- fm_rx_init_1273.2.bts
- fm_tx_init_1273.2.bts
- fmc_init_1273.2.bts
3. go to /system/etc/wifi and using Root Explorer <copy><tiwlan.ini> and <paste> to root of SD Card
4a. use USB Cable <mount><copy><tiwlan.ini> file from SD Card to desktop
4b. rename <tiwlan.ini> file on SD Card to <tiwlan.ini.1>
5a. do the necessary modifications according to Graveir's post @ XDA-Developers using NOTEPAD --> <Save> the mods to <tiwlan.ini> file on the PC desktop
5b. there are reports saying that "adhoc" mod is not working so I am not recommending it
6a. use USB Cable <mount><copy> modded <tiwlan.ini> file from desktop to SD Card
6b. <unmount> Xperia X8
7. <Launch><Root Explorer>
8. go to SD Card <copy><tiwlan.ini> and <paste><replace> to /system/etc/wifi
9. Reboot
And that's it... say goodbye to 802.11G and enjoy your 802.11N wifi!
cheers
Do or do Not... there is no Try - Yoda
Method:
Look for these lines about halfway down the page: change from 0 to 1
HT_Enable=0 ---> HT_Enable=1
BurstModeEnable = 0 ---> BurstModeEnable = 1
Single_Dual_Band_Solution = 0 ---> Single_Dual_Band_Solution = 1
(Be Careful - just change the numbers - do not add/delete blank spaces)
9. Reboot
cheers
NOT WORKING?
Not Connecting to Network
go to <settings><networks><wifi> erase all remembered networks and <reboot>
Reverse the Modification:
USB <mount> Xperia X8 - go to SD Card <delete><tiwlan.ini>
Launch <Root Explorer>
<rename><tiwlan.ini.1> --> <tiwlan.ini>
<copy><replace><tiwlan.ini> back to /system/etc/wifi
<reboot>
UPDATES:
Confirmation: Xperia X8 running 802.11N Draft - 2.4GHz @ 65Mbps
Battery Drain? - Nah... left my wifi on all the time with no significant changes in battery usage
miniCM RC1, CM7-J005, CM7-RC4 [Working] - so go ahead and mod
Floyo-0.15 [NOT Working] - so don't try the mod
Stock Android Eclair 2.1.1 [NOT Working] - don't even think about it![]()
