A small MOD inspired by Fuzzy13. The MOD consists of:
- The addition of the Flash LED found inside the LG hidden menu to the Settings.apk in order to use it as a flashlight.
- A shortcut to the Metropcs hidden menu section that allows you to disable/enable data
- A shortcut to Rom Manager (provided you have installed at least the free version, otherwise this option within the Settings will be of no use to you)
More Options/Tools/Shortcuts are to be added (need your suggestions). Keep in mind that in order for this shortcuts to be implemented they need to be kind of for everyone to use since I won't be able to keep up with any personalized requests.
Suggestion List:
-GPS Toggle suggested by Anniedroid
-Terminal Emulator suggested by ldrifta
-Advanced Bluetooth Settings suggested by Me
-DSP Manager/Equalizer?* suggested by Me
Red=not done
Orange=working on it
Green=done
Download the Original Settings.apk (Flashlight, Data toggle, and Rom Manager) HERE
-Original + Advanced Bluetooth Settings HERE
Instructions:
-If downloading to a PC,
plug your phone to your computer>internet mode>open Android Commander (or push any other way you know how)>place inside /system/app>No reboot needed.
-If downloading to your phone,
using your favorite File manager (with root access) move the Settings.apk inside /system/app>Reboot.
Thanks to Fuzzy13 for the inspiration (show some appreciation by thanking him) and thanks to anyone else that enjoys my MODs or uses them as bases for their own "experiments"
