Fuzzy13
Extreme Android User
Thanks to VSuperUserV, he has made a better and more efficient looking settings mod. Mine was an edited PNG but the link was still there.
VSuperuserV managed to change the text and delete the link, so the link goes no where.
MAKE SURE YOU THANK VSuperuserV BELOW!!!!!!
This is HIS work!!!!!
Download
#1- http://d-h.st/zVg (With link, like pictured below)
#2- http://d-h.st/SYg (Privacy link is gone)
Very useful so that we can eliminate the problems that come with people doing a factory reset in settings and not in CWM like they are supposed to.
Maybe we can get this implicated into the themes and ROMs so it becomes a standard and we can eliminate this problem 100%.
ALSO. If anyone wants to take on the challenge of making it "link" to recovery then go right ahead. Just download the "new modded" settings and PM me when you are done so I can test it. I'll then add it to the post. THIS WOULD BE IDEAL, if anyone can do it. All we need is the "reset in CWM" link to go to recovery just like in the power menu. I know someone can do this
Enjoy
Download
Enjoy
