Root [MOD] Themed Swype
Steven58
Former Heavyweight Champion of Android Forums
Moderator
Credit to bad4u6669
Link to mod:
Themed Swype - xda-developers
Different colors at the bottom, delete the color from the file name when placing on sdcard. i.e. blueupdate.zip > update.zip
MUST BE DEODEXED
All Swypes have matching tracers
All these are for 2.2, there is no reason you shouldnt be on 2.2
Original images from bilbobrian, just some extra days on my part getting it to you
As always do a back up
If on 2.2 and have boot strapper installed to use this update .zip, throw it on sd card, open droid x bootstraper reboot to recovery, apply update.zip, reboot done!
........ without bootstrapper method...........
if you want just the apk for a different color just extract it from the update.zip file
use root explorer or other app to make a copy of your original app ( its in system/app)
First you must remove swype.apk from system/app
any way of your choosing, terminal or adb, then reboot.
follow the following directions
Put the .apk on your sdcard, navigate to it with astro or your fav file browser, open the apk and choose install. If it still says only gives you the option to uninstall, you didnt uninstall correctly.
if you can get it to show up after install go into settings and keyboard and make sure swype is checked
DONE
................ If you somehow botched it...............
restore your back up.
If you were careless enough to not do a back up and your on 2.2 get a clean download here.. MY droid world 2.2 follow those instructions.
then download file again, your last one might of been bad. When in recovery go to mounts and mount system, then install the zip
I'm liking the shifted blue one but I don't see a download link for it? Also the directions do not go into enough detail to show how to delete the swipe.apk using the terminal. Anyone have directions how to do this?
N/M I feel foolish I found the directions in the thread, but still not sure where to get that keyboard.
Thank you, bro. The links are on the pages the devs had put up on the other sites. The links are above. I just wanted to help our folks become aware that there were swype mods.
I tried the Themed stock keyboard and it didn't work for me I don't think anyways. I still can't find the one I was looking for. I hope more of these come out soon.
