Root Modded LGSystemUI.apk!
M
Member1614188
Guest
I took the SystemUI apk and removed the ugly Sprint PCS signal bars. Replaced with the regular ones. (Haven't edited QSlide/Data icons yet, that's planned though..for QSlide I have to decompile and recompile. And data icons are weird.)
Screenshot:
...but if it's posted in all things root...you'd expect you need root. Also there are screenshots.
!!!! To change the systemui icons to any carrier, change in build.prop ro.build.carrier or similar to whatever you want! Like TMO, VZW, ATT, etc.!!!!
Three letter code for international? I tried some and it crashed systemui
ro.build.target_operator=US
ro.build.target_country=OPEN
or for Korean (same as intl.)
ro.build.target_operator=SKT
ro.build.target_country=SK
don't try this on the F3, it breaks everything.
When i changed the code I get Roaming Indicator Off instead of my carrier do you know how to fix this?
There is no way to fix this as of now. (Any carrier you try will give you this error...even if Roaming is on.) It's just to show right now that changing data icon set from SPR to any other works.
