Well if the apps you are referring to are games i would use rom toolbox to EDIT the build.prop
change the model and manufacturer to
GT-I9100
Samsung
ro.product.manufacturer samsung
ro.product.model GT-I9100
I used that and was able to play gameloft games and download em.Might want to look around and see what others work.I had to become a "droid razor" for some game lol.
GT-I9100
Samsung
Just back it up before making changes
What's the model number if I want to change it back ?
ro.product.manufacturer LGE
ro.product.model LG-MS840
Your welcome,anything I can do to help and me too(rooter)Man, thank you for that. I really appreciate it. I'm kinda of a regular rooter, and I like to enhance my phones potential.
,lately i been trying to figure out battery drainage issues,I have found some and still running tests on them
ro.build.description=GT-I9000-user 2.3.5 GINGERBREAD XXJVT release-keys
ro.build.fingerprint=samsung/GT-I9000/GT-I9000:2.3.5/GINGERBREAD/XXJVT:user/release-keys
that name tells the apps what phoen you have and thus will allow certain apps to run, google play however uses the device keys
for instance here is a I9000 build.prop
this is what the google market reads and decides what apps will work etc, so make sure you change the device name/model etc with these keys
o... well like i said its been a while LOL maybe you do also change those.. but i thought it may cause an unneccesary issue :/I switched my build.prop back to the original manufacturer and model and apps that were compatible with my phone are not now
Can someone post their own tweaked build.prop??? Saves the noobies time and headaches. With the modifications to allow any app download from the market.
