dsmryder
Android Expert
I tried to search for this, but I'm not sure what to search for.
What I am trying to do is add apps to a ROM that doesn't have the /data partition in the installation "update-script". I'm sure I can do it if I knew better what I needed to find. I think I would need to add some "mounting" parts, then "extract" parts. I can add the files to the /system/app folder, but that doesn't work for all of the apps. I think some need to be made to be run from there.
I'm also hoping this thread will help other MT users to tweak the ROMs they download. Personally, I don't like having to uninstall the same apps when I get an update. Plus, I like the "my account" app. I know it's only a link, but I like it.
idk know if "mmcblk0p26" is the right partition for /data so wait for someone elses input first
, but the command says it's /dev/block/mmcblk0p8
