Feedback on monster 3.0?
Personally, I'm not a fan of the xperia launcher (i prefer adw) or the blue-ish gradient thingy in the text fields (it looks dirty).
The honeycomb theme is nice; I like the overall color scheme, the bumbledroid icon at the bottom of the notification pull-down is a nice touch. I also like replacing the check marks with just a colored square.
I don't like Play Music. I don't sync my music and it seems to give me more problems than anything else. I prefer either the stock music apk or PlayerPro.
I do like the Miui camera better than the stock. The photo widget is also a nice touch.
I prefer the collapsed widgets in the widget select popup. Minimizes clutter.
Hopefully this is close to what you were after in regards to feedback. If not, I just wasted everyone's time (including my own). Muwhahahahaha!
Edit: I think you added stock swype back to 3.0, yes? Maybe not. Well I think it would be nice to offer more than one keyboard on the ROM. Say, stock android and then stock swype? Or maybe SlideIt or something like that.
