Root Monstro's Rom v10 ZV6 LS660 4.4.2 Fastest and Lightest Rom UPDATED 4/22/2016
The update PRL and Profile work now, thanks @grandamle91 !
I found another possible issue, though: where's the voicemail app? I tried installing a third party app, but Virgin Mobile doesn't support call forwarding (or whatever it is that's needed by voicemail apps). Am I missing it somewhere? Is there an app I can install to access my voicemail? I tried google voice and visual voicemail to no avail.
no way of sim unlocking, you must call virgin for that. you have to root yours and install TWRP, theres couple threads on how to
Laid this down clean - came from stock. I'm having trouble getting Google Calendar to work -- it keeps telling me that "Calendar Storage disabled" -- I've downloaded the gapps pkg and loaded it, but still no help. Any tips/tricks? Also - any way to kill the carrier banner? I'm using this on a RingPlus device, not a Virgin Mobile. Everything else seems smooth!
Two partitions, one std Fat32 (for media/etc) that is recognized thru Settings\Storage and a second ext4 (for Link2SD) that is recognized through Link2SD. Any other ideas?
The google apps pkgs I had been using were screwy apparently. I found another 4.4 pkg that I laid down at the same time I laid down the ROM and it finally worked. Thanks for the help!
by wipe everything what exactly do you mean? in twrp recovery theres advanced wipe, format, factory reset? what do you do?
should the yellow sprint logo still be here? and talkback? did i mess up?
seems like stuff's working just about to check if i have root access still so far so good i think
4th edit- I'm seeing alot of useless system processes did I mess up by not going into advanced wipe and wiping everything first? I wish the instructions had been more thorough.ing thing is connections optimizer popping up a lot not sure again if thats because i didn't wipe everything correctly. any help would be awesome
one annoy
Advance Wipe
