Not a problem. I'm subbed on the thread, so just write back when/if you've got it worked out. Thanks!
So is the device booting at this point?
Oh, yeah, it is. It just isn't fully functional (for one reason or another) on any of the custom roms I've tried. Wanted to go back to stock, but... Sd troubles, as I've mentioned.So is the device booting at this point?
If i knew how to compile roms myself
Look, guy, i read that, okay?
I cannot send MMS on this rom, and the cellular connection is very spotty now, much worse than on stock.I've got mine fully functional on this ROM. Phone, SMS, MMS, Data, Wifi, Bluetooth, Hell, I can even tether. Just the annoying triangle. Settings>System Updates>Update Profile?
Not going to make many friends that way. I understand the frustration, but know one gets paid to do this. Hard enough to get a like. 99% of the problem with ROM's turns out to be OE anyway.
We all say things we don't mean from time to time. You do know that you can edit previous posts right?
Seriously? I've already apologized
I know, I'm just saying in the future. Didn't mean to get you all worked up, but I'll digress and apologize. I didn't realize you were an experienced forum member. Your 14 posts threw me off. Still working on that back-up.
If you figure it out, I'd love to learn how. Always nice to be able to go back to stock, JIC.LOL... 14 posts here, that's true. I've been on many boards prior to this one, of course. I was a BBS guy way back in the day... before "the internet" was just AOL and Compuserve. 14,400 baud modems and all that junk.
While I've got your attention, though... What is a TOT file? I looked at that post, but sans instructions, I'm at a loss. (I will go ahead and download the files when I get in front of my PC, maybe there's more info in the .rar or whatever it is) thanks in advance
Edit (see, I'm learning) : I see now the post says there's instructions included, so we'll see if I can't figure it out. Thanks for the link.
Hi,
I just rooted my Ls660 with kingroot and couldn't get tether to work so I'm going to switch to supersu.
I don't know much about rooting but have done twrp once a year a so go but on a tablet not connected to a carrier.
If I use this will I lose my ability to connect to Virgin Mobile? I have an LS660ZV6.
And how do I do this step:
CAN ONLY BE DELETED IN A ROM>>>>Delete "/carrier/itson"
Causes issues with 4g and Won't let you boot custom roms
THANKS!
You will need to delete it manually with a file explorer. Please take some time and read through this entire thread. There is much to be learned. As far as eliminating Kinguser...you know that it isn't as easy as it sounds right?
Thanks, ok I have ESfileexplorer so I'll just delete the whole folder.
I just used the script from vicky bonick over at xda. I had some issues getting it through. I think because I had an older kingroot installed so I had to install the new kingroot and then try again. It seems to be gone but had to manually uninstall purify.
I'm going to research putting TWRP now it looks like the LS660 isn't supported?
When turn "data roaming" on.....Is this domestic only? How can I turn on INTERNATIONAL roaming?
This is untrue. I have worked on many VM LG Tributes at this point and know this to be untrue, also I have confirmed people in UK and Canada with VM Tribute in which international data roaming does work.
On the stock (atleast zv3 and zv4) rom it has a designated roaming menu. In this roaming menu is 2 options (4 total) Domestic and/or International and Voice and/or Data.
I'm probably going to answer my own question here, but i'm guessing i'll have to downgrade to stock zv3 or zv4.
I apologize......I had to dig out my old LG Tribute I had.....I confused the tribute with the VM LG Volt, which has the dedicated roaming menu.....Most of all the old stock rom VM phones have this roaming menu. The Tribute seems to have different setup system.
(turns out that's a known issue). I tried this ROM which looks like what I should have tried first - but the phone always boots into TWRP. I also tried the first ROM I flashed again and a stock ROM but no joy. Since I do have TWRP working is there some way to get running again or am I pooched?
.too light imho it's missing major components, and should mention OPENGAPPS
I'd say you're better off rebuilding it via superr's kitchen if you want, i could try my hand at building an alternative
