Root Most Stable ROM?
ModifHigher
this maybe a repetitive question,so excuse me in advance.i have the VM triumph and i dont care about the build or excess apps.what is the most stable current ROM feature wise?as in which rom has the least wrong with it?i know the best rom would be user opinion but i just want something that i can use as a daily driver and not have to constantly switch.
Thanks In Advance.
I have been using CM7 TG reloaded since begining of January. I have found it very stable. Night and day difference to the stock ROM. I've tried a couple of other ROMs but but have always returned to TG-reloaded.
Is hdmi and the camera working in the latest release of cm7?
camera works with the occasional fc. HDMI is a tough nut that the devs are only beginning to crack. also, in tg reloaded, the Bluetooth and wifi work fine...just not together. other than that it is a great rom.
Actually bluetooth and wifi work fine together. It used to peg your cpu at max, but it doesn't anymore...
I haven't heard anything about camera force closing either. Use my camera everyday.
Agreed, wifi and Bluetooth together works fine now, that issue has been resolved and I also use my camera frequently and have never had it fc.
Yeah TG Reloaded is the best so far. I'm using cm9 alpha cause it does everything I need and works great, I don't need camera or HDMI. I'm wondering if someone can point me in the direction of the thread with the most stable version of MUIU. I know they are working on MUIU w/ 4.0 but I don't think that's a daily usable rom.
Whysor took care of the wakelock issue in January. Battery life is amazing with CM7, which is one of the reasons I use it. There has been a bug for some people with the display not coming back on after a phone call, but this is related to the proximity sensor and the latest OC kernal v.1.7.20 fixes it if you have that problem.
On TG reloaded, is there still the bug that the phone will not go into deep sleep when wifi is on?
The bug was that it wouldn't wake back up from sleep with wifi on. The fix (TG) was to have wifi hold a partial wake lock.
So, yes. No deep sleep if you leave wifi (or BT) on.
This is all detailed in the first post of Whyzors CM7 reloaded thread.
Im running minimal triumph.I seen a table for undervolting Miui,but is there any refernce to good undervolting tips for a froyo rom such as this?
If you put a kernal that allows for it, you can use the same table as miui or TG. Get incredicontrol to change the voltages, and make sure you don't have set on boot enabled until you're sure it's handling the uv fine.
So I've been running mininmal triumph for a few days and I love it.
Undervolting -50 mV V6 supercharged and nothing to complain about.is there any way i can use apps2sd?I can move them using titanium backup right?
