I stand corrected Bionic is using Tegra 2
Full specs of the phone can be found here:
MOTODEV > Products > DROID BIONIC by Motorola, XT865
Isn't a .3 MP front camera a little behind the times? Also, only 720P recording and playback? Isn't one of the main benefit of dual core 1080P recording and play back?
Quote myself... haha, well the description says Record and playback of 1080P content but the spec's say 720P record and playback.
Its 720p record, and 1080p playback.
Where are you seeing that? I don't see it? To quote the description "Record and edit HD videos and then share them at 1080p"
Then if you look at the specs below it says
VIDEO RECORDING RESOLUTION (MAX) 720p HD (1280 x 720) VIDEO RECORDING FRAME RATE 30 fps VIDEO PLAYBACK RESOLUTION (MAX) 720p HD (1280 x 720) VIDEO PLAYBACK FRAME RATE 30 fps
Source: MOTODEV > Products > DROID BIONIC by Motorola, XT865
I'm going by 2 different sources. First, I heard Sanjay, and another rep both says 1080P playback, but 720P record. Second,
http://mediacenter.motorola.com/Fact-Sheets/Motorola-DROID-BIONIC-Fact-Sheet-353a.aspx
Ahhh, Ok. I didn't see that on either Engadget or the Bionic page on Motor's website.
Fair enough. Motorola seems to be sloppy with their paper work. Lots of conflicting information. Not just w/ this but also originally putting on their website that it would have 1gb of ram.
Sure is replacing my Droid X if it comes quick enough!
@%&%@+ Straight!!! Can't upgrade... but im saving some ofmy taxes for to get it full price. Then im ebaying my droid x... $350 starting bid. Lmao
I wonder how different the at&t and supposed verizon iphones will be
Verizon's lineup is the best it has ever been...
the new droid and htc, samsung and lg android phones
Iphone 4(supposed)
and the new windows 7 phone....
I am most interested in checking the Bionic(and Atrix) out to see which phone will make me switch back to Android(and to what carrier)
You know, I was just thinking the same thing. Are they even at CES? I know they are releasing their "Playbook" or what ever it is called. I have an 8330 Curve that is hitting the ditch for the first available LTE device.
Rim will still survive soley because of Corp America especially Gov or any DoD related companies. ...however they won't be anywhere near the top like Android and Apple.
1. BB's are a lot more secure
2. they have $hitty games which equal less playing around on your phone all day
3. How many awesome cool android or apple phones have you seen without a camera? Try getting one of those into a secure location. I think this is the one and only reason Rim produces versions of the bold without a camera.
I personally don't want a 4.3" screen, it's just too big for me. Because of that issue I'm kind of disappointed with the VZW's 4G phones introduced at CES this year, they're all 4.3". The Atrix is the phone I want...but alas, I'm tied to vzw.
I can upgrade my Moto Droid on July 13 of this year....looks like the Bionic is my leading candidate.....at this point!![]()
Typically 1.3-1.8mm of actual width added to the phone (based on Droid X vs. Evo vs. Galaxy S). Depending on the size of your hand and whether you need to add a case, that can be the difference between a secure grip on the phone in your hand or just having it by the fingertips. Those with larger than average hands or those who don't use a case may actually prefer the 4.3" (or larger) size. The average person using a case probably won't.Honestly what is the difference between a 4 and a 4.3.
