messenger13
Android Expert
Or any other LED flashlight app that I tried. Anyone have one that's working in Froyo 2.2. I prefer a widget ... but I'll take anything at this point.
No root LED torch. Only works with froyo.
Color Flashlight working for me
OK, sucky solution for now but "Sun lite" works. No widget...Click on app and it starts. No stop unless you hit the "back" button (bottom left)...
sun lite works ok.
All they're doing is firing up the camera app with the flash enabled, and then covering the screen with a pic. It did make me laugh though. heheOh nice! Because I would turn on mototorch before I opened the video camera to do this.when you go to the camera and switch to video it has a flash "on" option, so can use that till mototorch is fixed.
I will be fixing this in the next version. I have it working on my Nexus One running 2.2, so I will assume it will also work on the DROID.
Glad I emailed you and made you aware of it. I'm feeling naked without this widget. And you DON'T want to see me nekkid!![]()
And if you are a hot chick, nekkid would nice.
Now that there's funny...
Sun is working
But Sun isn't the same. You can't use other apps while the light is on. That, to me, is useless. I can use my camera app if that's all I wanted to do.
I do believe that with the changes in froyo, it means that my app wont be able to be used at the same time as the camera. But since using the flash with video is added by default now, maybe it won't be too big of an issue.
