Ok, i just registrated to this forum to get some help
I have a ACER Gallant Solo E350.
Had it 1 day and i already rooted it.
Today i bought a SD card from 16GB.
The reason i bought it is because i would like to use the card as USB storage or internal.
I have 4GB internal space. If i put the device in the computer, i see my SD card and 2GB of my internal for putting apps and other stuff in it. So that 2GB is the USB storage. That will show on my PC. The other 2GB that does not show up on PC should be the flash memory, right?
I don't want to mess up my phone, so some help would be awesome.
What i do know is that you can edit a file. Called: vold.fstab.
But the files which show how specific lines should be, does not match with my lines. So i will show you the content of my vold.fstab so that you can say how it should be edited.
Thanks for your help, just in advance
PS: i know that it explains how it should be edited, but i actualy still don't get it.
I am new at android modification. But i learn very fast. And i am not kind of a person 'i don't know how to use google'. I did a research for sure, but i just don't want to mess up the flash.
So i don't want to do anything where i am not sure about it.
## Vold 2.0 Generic fstab
## - San Mehat (san@android.com)
## Regular device mount
## Format: dev_mount <label> <mount_point> <part> <sysfs_path1...>
## label - Label for the volume
## mount_point - Where the volume will be mounted
## part - Partition # (1 based), or 'auto' for first usable partition.
## <sysfs_path> - List of sysfs paths to source devices
## Example of a standard sdcard mount for the emulator / Dream
# Mounts the first usable partition of the specified device
dev_mount sdcard /mnt/sdcard emmc@fat /devices/platform/goldfish_mmc.0 /devices/platform/mtk-sd.0/mmc_host
dev_mount sdcard /mnt/sdcard2 auto /devices/platform/goldfish_mmc.1 /devices/platform/mtk-sd.1/mmc_host
## Example of a dual card setup
# dev_mount left_sdcard /mnt/sdcard1 auto /devices/platform/goldfish_mmc.0 /devices/platform/mtk-sd.0/mmc_host/mmc0
# dev_mount right_sdcard /mnt/sdcard2 auto /devices/platform/goldfish_mmc.1 /devices/platform/mtk-sd.2/mmc_host/mmc2
## Example of specifying a specific partition for mounts
# dev_mount sdcard /mnt/sdcard 2 /devices/platform/goldfish_mmc.0 /devices/platform/msm_sdcc.2/mmc_host/mmc1
