G
gregtrips
Guest
Should I move any apps that allow me to move them to my SD card? I ask this because my phone started becoming really slow, it jumps instead of showing any transitons.
If you don't know what being rooted means and it's a new phone,then your not.I'm not sure what being "rooted" means. I believe my phone isn't. It's not like I have many apps. I moved some apps to my SD card, only the ones that allowed me to do so. The good thing about this, is that if it becomes really slow. I can easily reset the phone and start fresh.
Get watchdog lite and it will monitor the apps and call to your attention those that are hoging the battery.
If not really the only thing you shouldn't put on the sd card is widget apps. They will just not work right.
That's what were all here for.We get freely,we give freelyThanks? It's all too much to take in. But, I'll eventually get there. Thanks.
.This is why it is very important to install a custom recovery right after rooting your device so that you can backup your system, so if you have an oops you just restore and your good as new.Short version: rooting your phone gives you superuser permissions-- like admin permissions on your computer.
You can't get it accidentally, you have to do it on purpose.
It allows you to use apps that you cannot ordinarily use, but it also gives you permission to turn your phone into a $150 paperweight.
With the IPhone You can't install a costom ROM like the one I'm running. It has more customization tweeks the you could figure out in a month. You can do anything you want to a rooted phone,and we do.Sucks for your $150 paperweight. I know many out there have rooted their safely. Though, I'm not willing to take the risk. But, what so useful about using apps that you couldn't and have admin permissions? Besides the obvious.
Rooting is to Android as Jailbreaking is to iPhone. Correct?
Have an iPod Touch, which I Jailbroke. But, free apps and downloading straight to phone didn't give me the impression of it being the ultimate, superior, perfect device.
