Help move to sd
gmenfan83
Android Expert
ok this may sound dumb but how do i switch so that my apps and photos go to my sd card and not my internal memory?
You're photos should already automatically save to your sd card in DCIM...I had to move my apps through settings>applications
Cool thanow I am just wondering because when u view my gallery there is a folder in there that has one pic in it and it says SD card.. so if they all save to the card I am wondering why there is this one pic labeled SD card?
are you using another camera app? I think when I first used fxcamera it saved my photos into its own separate folder on my sd card. I had to change to settings to save in the default folder.
