i found a way for you all to use cwm to flash.
. Disclaimer:
. I'm not responsible for what you do to your phone!!!
MrRee???Rom -v.0.3
(tested on Boost Mobile, might not work for sprint)
Fast!!!
Smooth...
Increased Battery Time
Disabled Carrier IQ!!!
now your privacy is yours alone!
Screenshots...
added LOTs and Lots
added (update later)
speed tweaks
Deodexed
Removed a lot of bloat ware
removed Boost Mobile ID
removed... ummm.. (update later)
many more updates to come...
How to install with CWM
(the improper way that is)
- download... unzip the file in to /sdcard/clockworkmod/backup/
- reboot into cwm
- BACKUP YOUR PHONE NOW!! (save a backup on your desktop!)
....after backup....
- wipe data/factory reset
- yes -- delete all
- backup and Restore
- advanced restore <=------<<<
- MrReeRom
- Restore system
- Yes -Restore System
- Reboot
If you get an md5 error ---> try downloading zip again
- first reboot will take about 2-5 mins
- once finally loaded let the phone sit for another 3-5 mins to load all the applications for the first time
( you might have a "dock rubish data" notice, its ok... will be gone after first reboot)
- reboot
- set up your wifi and blue tooth first, then set up the auto bluetooth and auto wifi, then reboot one last time
you should now have a very fast and smooth phone
check out all the added apps and widgets
enjoy
****** If Upgrading From a Prior Version *******
If you are upgrading for a previous version of MrRee?
. Disclaimer:
MrRee???Rom -v.0.3
Fast!!!
Smooth...
Screenshots...
added LOTs and Lots
speed tweaks
Deodexed
- reboot into cwm
- yes -- delete all
- MrReeRom
- Restore system
- Reboot
- reboot
enjoy
