First you need to restore laf.img (this will remove CWM)factory reset get it back to how it was went i got it out of the box
ahh goody goody seems easy thank you, should i make a video it seems that there is very little video tutFirst you need to restore laf.img (this will remove CWM)
https://mega.co.nz/#!5h93lRyJ!3T_woM7e2W8xB8jNA4MPsSaOfEPe1cNhIzClv2aCHH4
How To: Boot Into Phone, then (in this program) hit B
http://androidforums.com/threads/tool-lg-laf-recovery-multitool-v1-2.863389/
Then you'll need to flash the firmware B (or C) *.kdz
Firmware B: https://mega.co.nz/#!gEBUwbSL!uwV7xNayicLoN8iAkipjaXy3mQ7NbcCWVzx8Lb43i18
Firmware C: https://mega.co.nz/#!1dhAnIaB!672_QhBjj0DZUJkflcE3EJU2GxkoKoxgmjRMUBxRDjo (can not root. If you do this, to root you must go back to B)
How To: http://androidforums.com/threads/unbrick-twogbsds-simple-unbrick-guide.864922/
Go for it! I personally don't like using videos for else than showing features and a few other smaller stuff, but everyone's different! I'd be willing to link some to it if they needed.ahh goody goody seems easy thank you, should i make a video it seems that there is very little video tut
Be sure to leave how to (text) in description though, might help some.Very nice.yes of course ill do ill spend all day tomorrow on it
Thanks
;P The only issue is that I don't see anyone else with this issue... So... ROM?It happens man, trial and error![]()
I can confirm that less than a week ago when i was running CM12 for the MS323 that after installing link2sd "plus version" after auto linking internal data to ext4 my apps would disappear a couple at a time especially after rebooting! Now im started over fresh on simplicity until u studs hopefully fix that. Thanx 4 all ur efforts!;P The only issue is that I don't see anyone else with this issue... So... ROM?![]()
Also i dont know if it matters but i thought it was because i had too big of a partition (6gb on a 16gb sd card) so i was tripping that i damaged my sd card and that was why apps were disappearing after linking them. However my sd card is fine after all. I repartitioned to under 2gb now on simplicity.I can confirm that less than a week ago when i was running CM12 for the MS323 that after installing link2sd "plus version" after auto linking internal data to ext4 my apps would disappear a couple at a time especially after rebooting! Now im started over fresh on simplicity until u studs hopefully fix that. Thanx 4 all ur efforts!
Thanks, I'll add.Bug Found! This is on both CM11 + CM12. Screen casting doesn't show anything, or returns an error on the display screen.
Thanks for confirming.Also i dont know if it matters but i thought it was because i had too big of a partition (6gb on a 16gb sd card) so i was tripping that i damaged my sd card and that was why apps were disappearing after linking them. However my sd card is fine after all. I repartitioned to under 2gb now on simplicity.
hey i cant get laf.img to restoreDoes anyone else on CM12 have Contacts FCing?
What's happened? What did you do?im stuck in boot loop i think i brick my phone![]()
Things are happening, be patient.hopefully you get a new build out soon i hate the og form of this phone
i know just tell me when homes lolThings are happening, be patient.![]()
I've been home for a while but not building anything yet, working on some other stuff - plus I know that there is more that will be coming soon.i know just tell me when homes lol
