Use the data fix i postedhey any updates bro really need a data fix
how i cant get it to workUse the data fix i posted
download s manager from market ..click on your sh file and hit su and net than reboothow i cant get it to work
and i think i am closing in on a camera fix http://review.cyanogenmod.org/#/c/82465/
Thanks for helping. Not using CM12 ATMdownload s manager from market ..click on your sh file and hit su and net than reboot
s manager = script manager from playstore , sh file as in net.sh that is posted in the fixes and finally were does that file go and if this is all right, then I've tried this and i got a error about permissiondownload s manager from market ..click on your sh file and hit su and net than reboot
hey is this anywhere close to fixing the camera http://review.cyanogenmod.org/#/c/82465/Thanks for helping. Not using CM12 ATM
Got to disable wifi firsts manager = script manager from playstore , sh file as in net.sh that is posted in the fixes and finally were does that file go and if this is all right, then I've tried this and i got a error about permission
okay answer thisGot to disable wifi first
if fi error add another fi i usually just put it in init.d directory and change permissions to the same as every other file in thereokay answer this
where does net.sh go directory wise
I've run it before I get two of which errors fi or permission failure
which rom are you currently running?Thanks for helping. Not using CM12 ATM
Most likely not. The issue resides with Kernel and Libs with our builds. Not CMhey is this anywhere close to fixing the camera http://review.cyanogenmod.org/#/c/82465/
Just bought more ram for my laptop and am downloading sdk tools you got repos for cm12? I plan on trying to fix the libs with the cameraThanks for helping. Not using CM12 ATM
Stock 10b. Would love to move to CM12 but need torch.which rom are you currently running?
Check chevans. I have a link around here somewhere. Gimme a sec. Btw, to fix the libs you probs wanna work with CM11 and then work up to 12Just bought more ram for my laptop and am downloading sdk tools you got repos for cm12? I plan on trying to fix the libs with the camera
nvm found them Thanks thoughCheck chevans. I have a link around here somewhere. Gimme a sec. Btw, to fix the libs you probs wanna work with CM11 and then work up to 12
https://github.com/chevanlol360/Local_Manifestnvm found them Thanks though
hit me when you release, do you where i can find a guide to set my phone back to factoryAlso trying to make my own build.![]()
http://androidforums.com/threads/unbrick-twogbsds-simple-unbrick-guide.864922/hit me when you release, do you where i can find a guide to set my phone back to factory
jess and how do i do the factory reset if i cant access download modeTo go from stock to CM12, or to not to. That is the question
Can you access recovery?jess and how do i do the factory reset if i cant access download mode
Wait... Are you trying to factory reset or flash kdz?yes through cwm, i already tried going into advanced and selection boot into boot loader
