Since I installed CM7 (CM7-TG-Reloaded), it's been like a new phone. But the last week or so all of a sudden my ringtones set for contacts are ignored and the default ringtone is used. If I clear the Dalvik cache that fixes it but only temporarily, it starts to happen again, usually after connecting to the PC but not always. I can clear the Dalvik cache quickly through one of the Titanium Backup options, so I don't even need to go into CWM to do it anymore, but either method works, TB or CWM.
Things I've tried so far, all with no change: I've reformatted the sdcard. I've changed the sdcard to a new one and double the size, 16GB Class 10. I've moved the ringtones from the sdcard to the phone's internal memory. I've moved as many apps as possible from the phone's internal storage to the sdcard. I've removed any recent apps I added. I've cleared the cache of all apps. I've disabled Battery Doctor, Juice Defender and Android Assistant thinking one of them might be shutting down something essential to save battery after an update. I don't use any widgets. I've added Ringo app that manages ringtones but that did nothing either.
Any idea what could be causing this? Short of flashing the ROM again and setting up new, is there anything else I can try? And any idea how to prevent it from happening again?
... it's really breathed new life into the phone. Especially now that I can go for days without having to charge it. I hate to see it in less than perfect condition after serving me so well (weird, I know!)
