Help MTP kies self starting. HELP!
When I plug in my charger, my s2 seems re think it is being connected to a pc via usb. All applications are exited and the media scanner buzz thing starts.
Annoying..
Can it be changed or is my phone faulty??
This hasn't happened to me so I don't know.
The most helpful thing I can do is suggest that you ask in the main forum not the rooting sub-forum (which is dedicated to hacking the OS rather than how to use the phone). You are much more likely to get a helpful response there.
Good luck.
