iLoveTherese
Hi , my Android tablet won't turn on
as in when i pressed the Power Button nothing happens
its full charged so the problem is definitely isnt the battery
i think it started a few hours ago
i tried to turn on my tablet but it wont
it kept on going to recovery mode
there was only an android avatar lying down with a red triangle on top of it.
there wasn't any options just the avatar
i turned my tablet off and on again
but it still booted there
after a few minutes i found that the volume up button was stuck
making my tablet go on recovery mode.
after i freed it
i turned my tablet off then when i tried to power it on
it wont start up
what happened? and what will i do ?
~thank you
my tablet is
made by Onix
Model number : TB512-16G
after i freed it
it wont start up
~thank you
my tablet is
made by Onix
Or perhaps find a forum here that can help
