SB13X
Android Expert
Just thought I'd share my battery usage for you all and my settings.
I DO NOT USE A TASK KILLER. They are useless.
The phone is rooted however I am still on a stock ROM for use of ClockWorkMod Nandroid backup, screenshots on phone and custom bootloader.
I'm using Launcher Pro with one home screen and all 3 scrollable docks.
Multi Live Wallpaper to size my wallpaper properly to a single screen.
One power control Widget: Extended Controls https://market.android.com/details?id=com.extendedcontrols&feature=search_result
Toggles used are:
2G-3G / Data / WiFi / BT / GPS / 5 Tier Brightness / Volume / Battery / USB Mass Storage
No flickr/HTC Sense Account the former due to its constant use of the calendar draining battery and the latter constantly using data draining battery.
All other accounts GMail, Facebook, Twitter all syncing every hour but for FB and Twitter usually constantly over 10 hours as I never leave em alone.
Apps constantly running are Whatsapp, 3G Watchdog, Widget Locker, LookOut.
Data is always active for 10 hours minimum and for the other 14 WiFi is usually active.
Here are the screenshots of my battery usage page over 5 days (I included the home screen shot of using the Current Widget as I had a look to see if deleting my battery stats would change anything and it didn't):
Toggles used are:
Just want to give the naysayers some proof that the battery on these things is more than sufficient and if your going to be away from a charging point with a couple of tweaks and being economical with your phone usage you can bridge the gap to the next power point.
