Root My Gps isnt working?
I've had this issue. rebooting usually works, sometimes needs more than one attempt. Try rebooting after turning gps off, and or with gps on. I had to reset on one occasion but hopefully this won't be a frequent occurrence.
Sid
The back story is it just stopped working one day?? i talk to Nils from Xda he told me to update my radio to the newest radio which i did ?? Still not working?
so, it stopped working right after you flashed a new rom?
have you tried restoring a nand backup?
What rom are you running?
Need as much info about your phone as possible to troubleshoot.
Moving this to the root section.
Definitely sounds ROM related. +1 for more info and it'd be nice to test on another ROM to verify function.
I'd try this first but I would also boot into recovery. Wipe both caches and reboot. My phone wouldn't recognize my internal memory and this was what finally worked.
