The only problem is when it reroutes! It takes about 30 seconds to get to the point where it will talk, then it will reroute itself and just mess up!!! I know this is pretty dumb, but is there anyways to prevent rerouting manually?
Just to get the nomenclature straight, you seem to be confusing "GPS" with your navigation app. The GPS is the device on your phone, which can be used by many different apps. This is what is broken. So the navigation app get confused.
