Root My hero, my touchscreen [Not functioning]
tanna
Hey people!
I don't know what happened but out of a sudden,
my Hero touchscreen just wouldn't work.
It's only the corner left and corner right or the screen.
I tried rebooting, reformatting to no avail.
I even do a nandroid restore but all my apps was gone! =(
So I did a restore of a much earlier Titanium restore.
This is really frustrating as I can't even pull out the num pad when in a phone call.
I'm using villainRom12 btw, idk if it actually matter.
Have you tried a factory reset? If it's a software glitch then that should sort it. If it doesn't then the issue is probably hardware-related and will require repair.
