when I plug my Optimus V into my PC, I get battery charging, and an icon on the phone to enable USB mode.
when I plug the same phone into my laptop (issued from my work/job) I get battery charging but no icon to enable USB mode on the phone.
is it possible there is some security on the laptop that prevents USB mode on the phone? yes it is a work issued computer and it has a lot of security crap on there. if this is most likely the issue, any idea where I should look to disable it temporarily if I really need to copy a file off my phone?
thanks
thanks
