My phone quit ringing!
sbbamafan
Member
I have CyanogenMod-6.0.0-Heroc with Kernel 2.6.29.6-cyanogenmod ameer@darchstar #2 (whatever all that means). I rooted and installed CM6 a couple of months ago. Things have generally been pretty good but with a few weird occurrances - nothing I could not live with given how much better everything was that it was originally. As of about 10 days ago my phone quit ringing. I checked and it is not silenced. I have also checked to make sure the ringtone did not get changed. I have rebooted and pulled the battery numerous times. I just cannot get it to ring.
As an aside that I am sure would remedy this, is there a new stable version CM6 ROM that I can use. Can someone refer me to a simple way to backup everything and change the ROM?
Thanks in advance!!!
Titanium Backup is great to backup your apps. I use it and it always does what I need.
Yep, wipe davlik cache and cache. Then flash the new stable 6.1. All settings will be as you left them;)
