chevyboi89
i have sucessfully rooted my 100% stock fascinate running Di01 using this meathod here: http://androidforums.com/fascinate-...-rooting-fascinate-regardless-os-version.html
Im looking at putting Froyo on my phone from this thread: http://androidforums.com/fascinate-all-things-root/269573-how-install-dl30-aka-froyo.html
but im seeing some ppl are having issues with sync, backing up contacts, and some other small things.
not sure if i wanna go through with this quite yet, so i mite wait it out until all the little bugs are worked out.
before 2.2 came out i saw threads on how to put DJ05 and DL09 onto the fascinate. i was going to do this earlier, but had the wrong version of Odin, and nothing would send to the phone...now i have the correct Odin for the phone, but i cannot find these updates any longer. tried looking for them in search forums option, but no luck. so if someone could link them that would be great.
i heard either of these will fix the GPS, i use GPS alot, does one work better? also just in general [not just GPS wise], if one works better, which one would that be? [youcan vote in my poll, so comments are not being junked up in this thread on debating/fighting over which is better]
my biggest concern with changing up my phone after i choose whether i want DJ or DL is that when i do this update, i want to change everything. i want to add a ROM, the kernal, and put a theme on it. in what order should i be changing things? i know the theme goes on last because it depends if you put on DJ05 or DL09...but ROM or kernal first?
when i look at ROMs i see ppl asking if it deodoxide [sp?] what is that?
and as for kernals, im looking for something overclocked nothing crazy, but an improvement. also would like it to be under volted for when at idle. what are my options? do all ROMs have themes built in? or is there any ROMs available without a theme, as i would like to find my own theme, i personally like.
lastly, i always see "make sure to make a nandroid back up" when doing anything to the phone on the forums here. where do i do that? is nandroid an app i DL in the market? is it something/somewhere already built in stock on the phone? icannot seem to find any info on this anywhere? so if someone could help me out here, it would be greatly appreciated, im really lost on alot of this!
