Root Nand unlocked?
I may have found the answer at xda:
or try to mount the card: (*note, this command only works from recovery. If you are inside the android OS you have to use adb remount. This is also how you test system r/w access, which is what this whole process gives you
Code:
adb shell mount /sdcard
if I understand this right, do I just boot my phone, plug it in to the pc, and run this adb command. If its sucessful then I am good to go?
No, you are reading the post incorrectly. Being "NAND unlocked" means you have the ability to mount /system as r/w (not /sdcard ... /sdcard is r/w out of the box ... otherwise, how could you put files on it???).
Dunno. Figured out when i could backup and restore to nandroid that I had access.
But I dunno if you're understanding what i was asking. I understand I could read and write to the sdcard.
Anyways:
/thread
