I am pretty new to the whole rooting stuff. Recently rooted and flashed with Salvage Mod and a Tiamat kernel. My question is I keep hearing about doing a Nandroid so that if you don't like a kernel or ROM you can easily go back. Does this mean go back to all the apps I had previously installed as well or just basically the O/S and kernel and then restore apps using AppBrain or Titanium Backup?
Is it possible to make some form of a Nandroid Backup that would restore all my apps that are installed along with the settings or is that just too much to hope for?
I am also running Amon-Ra as my recovery tool if that makes any difference.
Thanks,
-Eric
Thanks,
-Eric
