slyd
I'm looking at Andy's guide for rooting. These directions are excellent but I am a little confused about exactly what should be checked when making a nandroid.
Andy's instructions seem to say everything except data and sd-ext should be selected. (If data is already selected and I select data again, then data is unselected.) I think Andy didn't really mean to select data a second time.
Also, I read in another guide that only the first three and wimax should be selected.
Do the same boxes get selected if the sd card is partitioned?
Maybe it would help in the instructions to have a list showing what should be selected before you make the backup.
Text below is from Andy's Excellent Guide to Rooting
25.
Now at the top of the screen you will see 'Return'. Press the power button once on 'Return'.
Nandroid backup
Now go to Backup/Restore and press the power button. On this screen you will see
[X] boot
[X] system
[X] data
[ ] cache
[ ] recovery
[ ] wimax
[ ] sd-ext
[ ] android-secure
Boot, system and data are selected already so using the volume down button and then using power button to select, select data, cache, recovery, wimax and android-secure. Each of these will then have an X next to it when selected.
25.
Nandroid backup
[X] boot
[X] system
[X] data
[ ] cache
[ ] recovery
[ ] wimax
[ ] sd-ext
[ ] android-secure
