Root Nandroid on .340?
Tmose04
Dont know if this has been covered but I updated to .340 for fab's new rom. If I wanted to can I put a nandroid on there from before I updated?
Don't restore a backup from the old bootloader. Once you updated to .340 you can only restore backups from that point up.
Sorry I'm a bit slow tonight. So I can only restore backups that are made for .340 now that I updated?
Yep, once you've updated to .340, make a nandroid from there before you do anything else, and delete all other nandroids that you made before.
If you use a backup from a former rom, then you will perma brick. Please do as my friend says. ^^^^^^ get rid of all your old backups.
Please delete all your pre-340 nandroids.
Where do you find the files to delete? I want to make a current backup but I want to get rid of the old 1st so I will only have a post 340 backup.
EDIT: Nevermind, I found it: sdcard/clockworkmob/backup if anyone else is wondering
