nandroid problems
barnacles
I'm trying to restore a backup through the phone, and I'm getting an error "run 'nandroid-mobile-sh restore' via adb!" Any help on what this means?
EDIT: Corrupt nandroid. Fixed :D
That is actually telling you to run your nandroid restore through adb. You should be able to open a cmd prompt, navigate to your adb/tools folder, then run the command that it says.
I'm not sure why it is telling you to do that.
What Recovery Image are you running?
Did you happen to rename your backup? Make sure if you renamed it that you have no spaces in the name. Also make sure the folder structure is the same if you moved it.
Glad you got it fixed :).
Thanks for the quick response! I did rename it, but since re transfered it to my SD. Must of corrupted in that process, for I simply transfered it from my computer once again and it worked! Lesson to everybody.. keep nandroids on computer as well! :)
