navigation bar
is there a way i can put a navigation bar on any rom? i had it on the cm10.1 rom but now i have the sgs3&4 rom. thats like the only feature i like, help please
Must be rooted
Use es filemanager or anyother of your choice
Go to the root of your phone "/"
Go under system and look for build.prop
Open and scroll and the lines at the bottom
Exit save and reboot
Tada!!!!! (:
ok i got it thanks! ;]
but this dont work on rooted stock rite?
Yeah, It'll work on rooted stock. You just have to use a different launcher 'cause this happens
oh ok thanks,
1 more question before u take off lol
im tryin to flash jellyerse and its not goin well,
im flashin with agat rec,
i install fb27
then the rom
then my gapps
now wen i boot up it takes a long time and it says system ui error and im missin 3g
what am i doing wrong
Need an ics modem
Jb modem on Jb touchwiz roms = no data :)
If your already on ics modem, simply ignore me then :p not familiar with this s2 :)
Hey if you're editing files with es file explorer, do yourself a favor and check what the file permissions are before you edit the file, and then after editing go back and make sure the file permissions are set correctly. Do this before you reboot!
