SCPadgeebar
I'll just reflash rom. And reflash all mods I flashed. Tnx anyways.
You seem to be stuck on media scanner.
If you have made any cwm backups in dup format, make sure you have a .nomedia file in the clockworkmod folder as dup format creates thousands of files within blobs folders which can drastically slow down the media scanner service.
It is good practice to create .nomedia files in any folder you don't want apps like gallery, music player etc. to scan inside. Remember this is recursive so all you need to do is create one in the top most level that you require, so no need to create in all subordinate sub folders.
If you have a .nomedia file in the clockworkmod folder then you need to clear out media cache. I've written a zip to do this which I could dig out for you tomorrow if you need it.
Yes ES Explorer will do it.
Once you have a .nomedia file, you can just copy+paste it into all other required folders using windows explorer.
ES explorer says Operation Failed Please use a Different Name? Do I need to alter permissions or anything?
Hello and thanks Sales for all your efforts and help!
I am having that problem (bug?) with lock screen that keeps frozen for a while befor I can unlock the phone.
What should I install in order to correct this problem?
Thanks my friends!
Use Root Explorer to make a nomedia (with a period /full stop at the beginning - SwiftKey won't let me type it out as it needs to be) folder on your phone, then cut and paste it into all the folders you don't want media scanner to look at.
Root Explorer can be found here :
https://play.google.com/store/apps/details?id=com.speedsoftware.rootexplorer
Just bought Root Explorer & in Clockwork mod there is already .nomedia file?
You didn't need to buy root explorer to tell you that. You could have used My Files or your pc.
Its ok as u can refund within half hour :-D
In ES Explorer it didnt show the file though! Seems odd, no other file app showed it.
Hate being a pain in the ass Sale but the fix for the skip songs didn't work for me... I use the google music app by the way.
I've an issue where I click a gmail notification and it closes the notification screen but fails to take me to the email. It doesn't occur everytime but hey if its a quick fix...
Same with the Contacts as well. Ideally, it shouldnt take more than 1-2 seconds...Anyone else with this problem? Whats the solution????
