Need an extra battery or two. Any recent reviews or recommendations?
xrae
The last couple of weeks, the battery life on my V has been dismal. I'm getting 1/2 a day, tops, before having to plug in. When I unplug, I can't think of anything I've done or downloaded recently that was out of the ordinary to cause the poor battery life.
I'm coming up on a couple events where I will need backup batteries because i won't be able to recharge throughout the day. Any of you have recent reviews or recommendations for third party batteries from Amazon or another seller? How about a battery with a charging station or dock of some kind?
Thanks!
I have had bad luck with the off brands sold on ebay. They dont fully charge and do strange things to my phone - I swapped one in after charging and it was only at 60% capacity but the disturbing thing was the date said 1980!!! The batteries lack safety features as well.
Id bite the bullet and buy LG/OEM batteries only.
I was actually going to start a thread today asking if anyone has had any luck getting a real OEM battery from an eBay seller. There are quite a few on there, but I've been burned in the past with a so-called OEM battery that wasn't (for my Blackberry), from a seller with tons of good feedback. If not eBay, where's a reputable place that doesn't cost a fortune?
I'm getting the battery for my V's 1st Birthday on Wed, BTW (yes, there will be a party). :cool:
Good battries cost money, even though the ebay knock offs could be off the same assembly line making them like OEM, quality contorl test could be skipped.
Id go right to your carrier or LG, also a good idea just cause how easy both would be on a return if say it was goofy.
extra cash paid for direct OEM is a nood n a wink payment to make sure your taken care of.
[Like getting a car battery from Sears or Walmart, neither is built different, Sears just stand behind DieHard and the extra cost ensures your taken care of if it fails.]
YMMV, but I like external batteries, as having to power down my phone when running out of juice while doing something critical kind of defeats the purpose for me
VM's website has no accessories for the V at all that I can find, and as I suspected LG wants 50 bucks for the OEM battery, which I honestly can not afford. I took a chance elsewhere and will report back when I receive it.
^ those item are just a bunch of rechargable AA or AAA battries that plugs into the USB port that lets it take a charge from them.
like plugging into your car when its not running, the battery is charging it.
were some early cheap ones you just put store bought toss away battries in.
Thanks!
LG Optimus S LS670 3000mAh Extended Battery+Modified Cover+Charger Free Shipping $22.99 Gadgets-N-Gizmos.com
This is a great battery. it looks like the price went up a couple bux since i got mine. It is a rock solid battery and works great in my V
Do you use quick settings to manage your use of gps/wifi/data and all that?
You're either using your phone hardcore or something is wrong
G19, I am completely hardcore! Ha ....
About a week ago I installed the app that monitors wifi and mobile data usage. That was the only thing different. I've uninstalled it, but still am seeing the battery drain more quickly. I do a lot of podcast streaming on wifi, which I know that takes a lot of juice. I also use bluetooth for most of my calls. GPS is rarely turned on. And I do use QuickSettings.
I'm not interested in an extended battery because my case won't work with it.
Thorsten, I've checked out the "Powerbank" and I have a couple questions.
This is its own battery that you recharge by plugging into the wall or a USB? or does it run on AA batteries?
How long have you had yours? Have you noticed any degradation?
Am i the only one to be paranoid of this external battery concept ?
Hearing horror stories of using non-OEM chargers would make me very hesitant to use such a doohickey... Or are these issues only limited to AC chargers ? I haven't used anything but the stock AC charger... never even used it straight PC->USB because my computer's motherboard has this 3x USB power "feature" to charge stuff faster.
Paranoia cha cha cha !
still got your old parts?
any way you could show a real comparsion of how much the thickness changes?
here are some pix that show the difference..
ImageShack Album - 11 images
I had one of those external batteries and it just got to be a pain lugging around more stuff.it now stays in my car.
Yes i have my original parts. Went with the larger battery as I use a nylon holster i found that works perfect with the phone whether it has the standard battery or the extended one on.
I could use a cheapie external charger that used AA batteries with my old phone -- not a Droid -- and I didn't have any issues. It won't power my Droid, though. I've tried.
This is its own battery that you recharge by plugging into the wall or a USB? or does it run on AA batteries? How long have you had yours? Have you noticed any degradation?
Yes, it’s a lithium-polymer battery. No. Since October. No.
I’d say that unless you absolutely can’t carry this deck-of-cards-sized battery, which weighs about the same as the phone itself, it’s hard to go wrong.
I received said supposed OEM battery today. First impression: if it is not indeed OEM it's the best darn knockoff I've ever seen. More later when I have had a chance to evaluate performance.
Just thought I'd report that I purchased (2) batteries and a charger from Ebay for about $13, shipping included.
I can only tell you that I've been using these (2) batteries as well as the original battery for over a year now, and all three of them have performed equally. Having the wall charger has been a treat.
