Root ~*Need Assistance With Rooting*~
Ohkay, I know rooting on the Admire can't get any simpler but, I can't seem to do it and I don't understand whats going. I have the phone fresh from the store bought today, and USB debuggin is enabled, and drivers are installed. I run the program and leave the phone on the counter to let the magic happen and nothing happens. Can somebody please help me. Thankyou in advance.
----EDIT I added a photo to show the result of me trying to root my phone with the given progam from the download.
1. Make sure you are running the .bat file as admin.
2. Try another usb cable. (Not all are the same!)
3. Try a different usb port on the computer. (this fixed this problem for me!)
4. Try checking all the options in the debugger menu.
5. Reboot phone after you do this to check settings.
6. Use a different computer. (Maybe this one doesn't like you?
And hey.. try these. Let me know how it goes.
Iight so I tried everything except another computer and another wire. Which I'm about to attempt. But in adavnce iss there any other tips, that you can spare? I keep getting that screen I attached with my orignal post. I don't know what the **** I'm doing wrong -.-
Did you download and extract the drivers http://k0nane.info/rom/indulge-drivers.exe
Got it done this way:http://androidforums.com/admire-all...dows-mac-linux-9-12-2011-a-7.html#post3958093
Superuser could be installed from within the files included with the root files-I just found it easy to install it from the market:D
