Sprint gps sucks, uses cell rather than gps (SAYS NO CELL SERVICE IN THIS AREA) and google navigation I can't save adress's for for later use. I work in ems and need to set hospitals and other places to pick quickly on the go..... any ideas?
I don't have a solution for you. But you should reword the misleading title of your post. You aren't looking for a different GPS. (The GPS is built into your handheld device, and its output is used by any number of apps.)
You are looking for a different navigation app.
And it sounds like you want an app that stores its map data onboard, rather than downloading it dynamically over the network.
