njbianco
I bought 2 OEM Samsung batteries 9not knock-offs) for $11.99 each
thats called luck
Well there was my old instinct external charger and battery sitting there staring at me, seemingly taunting me. Knowing that the instinct battery was very similar in shape I got kind of curious.... So I powered off, took off the back plate, took out the Moment battery, and slid the Instinct battery into place. Wow... kinda fits, doesn't really move around much, surely it wont work... Turned the phone over, held down the power button for a couple seconds... SAMSUNG.... IT WORKED! I let the Andriod OS fire up and the battery meter read 60%... not bad, considering the battery hasn't been touched for almost a month.... but, maybe a distorted read since its a different battery (less mAh)Here's an option....
Okay I'm surprised I no one has discovered this yet (that I've heard/seen/read)
If you were a previous Samsung Instinct owner, like I was, you are in luck!!! Because you have an external battery charger, and one or two extra COMPATIBLE batteries.
I was just sitting around tonight and picked up my phone (minimal use today) 15% batteryWell there was my old instinct external charger and battery sitting there staring at me, seemingly taunting me. Knowing that the instinct battery was very similar in shape I got kind of curious.... So I powered off, took off the back plate, took out the Moment battery, and slid the Instinct battery into place. Wow... kinda fits, doesn't really move around much, surely it wont work... Turned the phone over, held down the power button for a couple seconds... SAMSUNG.... IT WORKED! I let the Andriod OS fire up and the battery meter read 60%... not bad, considering the battery hasn't been touched for almost a month.... but, maybe a distorted read since its a different battery (less mAh)
Well, surely it will fall out of place with ease and the phone will power off rendering it useless. I refixed the back plate and shook the phone around. Still on. Dropped the phone on the carpet from about 3 feet up. Still on. Put it in my pocket and ran in place for a few seconds. Still on. Battery meter still at 60%
I haven't done any type of battery life test yet, but as far as I'm concerned this will be HUGE in the way I use my phone. No more "Conservative Mode" which I feel like I'm always forced to be in, because of its crappy battery life. Now I have 2 backup Instinct batteries, one of which can be charging while the other is in use.
So, while this is no official battery fix, or an appropriate external Moment battery charger, it should definitely help some folks.
very good info as i came from an instinct. wonder what the difference is in the batteries? is it not a direct fit?
The moment battery doesnt fit into the instinct charger as it is too wide. But, if you were to modify the instinct external battery charger by cutting off some of the sides with a dremel it should work. You would probably need to figure out a way to stabilize the batters so that it wouldn't move aroundAwesome to hear another option! Does the moment battery work in the instinct charger as well, or does the instinct battery just work in the moment?
I can do a little better than that. I don't have a good ruler, but it looks just over 2" by just over 1.5". Here are some pictures, including ones with the battery inserted. I just noticed that it says blackjack II on the bottom. I was under the assumption that the ace and bj2 were the same phone except for the front styling, but perhaps the battery size is different. What's odd is that the spare battery I bought for my Ace was listed as a BJ2 battery, and it fit just fine.
Amazon.com: Samsung BlackJack II i617 Cradle Charger with Data Cable: Cell Phones & Service
Can you verify that this is the charger?
I looked up the battery part number for the Samsung Moment and searched for a charger compatible with the battery. I found the following universal charger which looks like it should do the trick:
SAMSUNG M900 SPH-M900 Moment Universal Battery Charger-US, FREE Shipping, SAMSUNG M900 SPH-M900 Moment PHONE Universal Battery Charger-US
Same thing at buy.com at half the price. For under twenty bucks, it was worth it for me to try it. I'll let you know if it works.
Just arrived. Fits like a glove. Problem solved.
Wanted to get a couple tests in before replying.
Answer: quick and apparently full charge.
I put this charger side-by-side with the "must jiggle" one I had been using (see above). Charged in same amount of time. Phone indicates battery has full charge. Real world use seems to indicate that battery has full charge.
Problem solved!!
has anyone bought an extra battery, and if so from where?
Battery was completely dead and I think it was about a couple hours to a full charge.
