Hi all, I've been reading lots of threads about Voodoo kernels and what not, but am a little confused with all the versions out there including Ext4, overclocked, not overclocked, etc. I was wondering if someone could suggest which would be the best for me based upon the following things I want for my fascinate. Right now, I get a lag sometimes opening up different apps such as the gallery and some others, where the phone will literally be at a black screen for 1-3 seconds. Here is what I want for my phone:
I want something to fix this lag.
I want the same battery life or better, which means
I don't need/want my phone overclocked.
When the lag doesn't happen, the phone is plenty fast for me, though I wouldn't mind it being a little faster.
I want whatever kernel I use to be stable.
I want to continue using launcher pro.
I'd really appreciate advice as to which of the various kernels, JT's, Dirks, etc, would be best to have my SF meet the above conditions.
thanx
thanx
. But, yes I also noticed that outside the 1250LV which I cannot get to run at all. Every other kernel I tested can run in Performance mode and benched to death for an hour. But some of them will black screen as you say from sleep and/or from something apparently much less cpu intensive. I dropped a post somewhere today dont know if it was here or xda or where it was. But there might be a possibility that LP[+] and BW might not like the voodoo kernels; but by no means am I asserting that as a plausibility, yet.
