jtovar1998
I just converted my ROM from 2.2.2 to CM7 2.3.7. I was able to change my boot animation. I do not have a boot sound and want to know if anyone can tell me how. Thanks for help in advance.
When I changed to cm7, I lost Google play and all my apps even after backing up everything. So I started fresh. I can't get any of my apps back or market and need to know how to do so.
If you still have a titanium backup folder on your sd card then they shouldn't be lost. Their in there You just have to download a fresh Titanium Backup from the market in the new ROM to access the folder on the sd card.Yes, I used titanium backup and did all according to forums and somehow I lost everything. I finally figured out the gapps before getting a reply but thanks for yalls help. Now on to boot sound. The bclite changed my imaged to a slow version and still no no sound. Cm7.is saying that I have a binary but after more reading, I need to input some scripts. I did that but I don't think all the spacings or characters are correct. Let me know if anyone can help. Thanx
you could just download an app called boot sound changer...it will install the sound binary, and you can make your boot sound whatever you like,really easy...![]()
