Root Need Help Deodexing a ROM
PhoneMan93
I have been following this tutorial on this website.
But I get stuck at the command on step number 5.
I type "java -jar baksmali.jar -x am.odex"
But i get this error.
Any ideas?
Are you on Win7 or Ubuntu?
Because every time i open that the "Main" and "Test" disappear.
Maybe it was the version, I see they have 2.3.3 now, I was using 2.2.2.
...Norton just caught a Trojan in it?
win 7 for this
copy files from app into orig_app and files from framework into orig_frame
use Main Skip.bat
do number 3 and number 4
then go into 15 advanced and do 13 and when asked do extreme
when all is done the files will be in done_app and done_frame
but all the needed files will not be in there, any apk that did not have and odex file will need to be copied into there
win 7 for this
use Main Skip.bat
I used pull /system/app and pull /system/framework.
Then used deodex app and deodex frame.
I still have the done_app and done_frame.
Should that be fine?
And are you talking about apps like YouTube bc it doesn't have a odex file or you mean files i need to manually put in there from /app and /frame?
sure
if it did not have and odex file, it will not get copied into done
you can manually copy then into done before you optimize
some of the apks may cause the optimize to crash, i think the superuser apk may do that, so you dont want it in there when you optimize
do i need twframewoork-res.apk?
Can xUltimate optimize?
I don't theink framework-res had a odex but twframework-res.apk does so do i need to deodex that too?
I never really understood what deodexing does to a rom and what benefits we the consumer get out of it. SO if someone could explain what deodexing a rom means and what we get out of it it would be helpful. Ive herd the term before but I dont know what it entails
Try this link, quite informative.
Deodexing
Explained + How To
The DL's are for the Droid x, so don't use them but the info is there
