Need Help Fast Please Read and Reply
On my Galaxy s3 I was downloading a completely legal torrent through bitttorrent. The torrent was 6 gigs. I saved it to /storage/sdcard0. It has completely filled up my device. I went to settings then storage. It shows 13 gigs in downloads, but no files to delete. My question is: where do I go to delete this huge torrent? How do I do this?
Thanks.
Hello SatiricalNick, Welcome to Android Forums. Have you tried a file browser? Use it to scroll to he exact place you downloaded the file to, Delete it from there that way.
  • Like
Reactions: Doc
Thanks.
Also there are a lot of apps on google play store that can help with deleting files............;)
Use your Samsung file program, and check in your download folder, if not, then go to your Bit-torrent and check in settings where it downloads the files, it should be there.
Thanks.
The funny part is he ask for help fast and he is not even around, LOL
Or as mentioned, the Files app from Samsung, does the same ;)
