Root need help flashing htc evo 4g
Puppet2332
i got an htch evo 4g that i want to flash on to metropcs
its on software 2.3.5 android version
.... i tried using unrevoked but i get stuck... my computer cant detect the cell
and when my computer searches for the drives it says its up to date
ive also tried to install the drives (and yes they were for the 64 bit since my computer is windows 7 64 bit)... well wen i tried installing them manually it would come out saying it isnt for a 64 bit
ive tried everything ..... i need help
can someone help me, i need step by step help please and thank you
Unrevoked will not work for you because that vulnerability has been patched. Check out our 2.3.5 rooting guide for information on rooting
If you haven't already read this guide, here you go:
[GUIDE] HTC EVO on MetroPCS!! - xda-developers
okay.... i got nowhere specially since ur ""frenchy714" comment link, it has good instructions but their links dont exist
My major problem here is..... I need help with the ""DIAG"" drivers.....
ive tried looking for them my self...... the 64 bit version but each time i tried installing them... my computer would have an error message saying to check and make sure their for a 64 bit operating system
I think I still have all the files on my pc. I'll upload them for you as soon as I can
okay well i tried installing the drivers manually but an error message comes out and says;
"the folder specified doesn't contain a compatible software driver for your device. If the folder contains a driver make sure it is designed to work with Windows for x64-based system"
this is the problem ive been having ....if some one could please help me step by step....or through video chat so i could be showing you wats going on and you could help me with a solution.....
I apologize, I should have checked the links prior to referencing this guide.
Puppet, fyi the thanks button does work. So when people post useful stuff, go ahead and click that button. It yields epic amnts of win and tiger blood :P lol
i know im suppose to delete my htc sync but i wanted to see if it connects to it but it doesn't ....is that suppose to happen or am i missing other drive besides the diag## ones??
ok well i found the drivers. im trying to install them right now, i will update you as soon as i figure it out. (i have a windows xp that i did the programming for my evo)
lol so this became a thanking button thread??
lol.... i still need help with this :/
You're right, this thread did veer off topic a bit. It was a general comment that wasn't directed towards anyone in particular. With all the knowledgeable members we have here, I'm confident you'll get your issue resolved. Please keep us posted.
it doesnt detect it as an android.... it says unknown device....
ok i got it to work!
first method just install HTC Sync and uninstall it.
but if that doesnt work
you can try the files im going to attach to this thread. unzip it and put them on your desktop and leave them there. plug in phone, put it in DIAG mode (##3424#). now click start, right click computer, click manage. go to the device manager tab and you will see unknown. right click the unknown driver, select properties, then click update driver, next click manually and select the folder you put on your desktop and it should install. now you should see your phone under modems. now it will show up on cdma workshop and qpst. (mine is under COM16 if you want to know your just right click your phone in device manager and select properties and check under Modem tab, it will say COM:xx)
