Need help for problem
ebp0311
I have a rooted ZTE Merit. I have TouchNav Recovery, and stayboogy's AOSP Roamer v1.3c. I love, love, love it. It totally thrashes every other rom I have had... except for one point. When I try to download facebook, it installs and just before it completes it reboots. I am sure some folks advice would be to not have facebook. However, I want facebook. So under advice, I ran a logcat, and copied and pasted it to pastebin. The link is here Facebook attempt aosp - Pastebin.com
Any help would be greatly appreciated. Thanks in advance!
Hey ebp0311,
I'm thinking your thread would fit better in one of the all-things-root areas for your device, but I'm not sure which to move it to:
It does indeed seem like there's a memory issue encountered as a result of the Facebook app install:
Code:
E/dalvikvm-heap( 4578): Out of memory on a 595066-byte allocation.
I/dalvikvm( 4578): "PackageManager" prio=5 tid=13 RUNNABLE
I/dalvikvm( 4578):   | group="main" sCount=0 dsCount=0 obj=0x2b0213b0 self=0x1bde78
I/dalvikvm( 4578):   | sysTid=4600 nice=10 sched=0/0 cgrp=bg_non_interactive handle=1833792
I/dalvikvm( 4578):   at org.apache.harmony.security.utils.JarUtils.verifySignature(JarUtils.java:~155)
I/dalvikvm( 4578):   at java.util.jar.JarVerifier.verifyCertificate(JarVerifier.java:296)
I/dalvikvm( 4578):   at java.util.jar.JarVerifier.readCertificates(JarVerifier.java:265)
I/dalvikvm( 4578):   at java.util.jar.JarFile.getInputStream(JarFile.java:389)
I/dalvikvm( 4578):   at android.content.pm.PackageParser.loadCertificates(PackageParser.java:369)
I/dalvikvm( 4578):   at android.content.pm.PackageParser.collectCertificates(PackageParser.java:540)
I/dalvikvm( 4578):   at com.android.server.PackageManagerService.installPackageLI(PackageManagerService.java:6145)
I/dalvikvm( 4578):   at com.android.server.PackageManagerService.access$2300(PackageManagerService.java:143)
I/dalvikvm( 4578):   at com.android.server.PackageManagerService$5.run(PackageManagerService.java:4830)
I/dalvikvm( 4578):   at android.os.Handler.handleCallback(Handler.java:587)
I/dalvikvm( 4578):   at android.os.Handler.dispatchMessage(Handler.java:92)
I/dalvikvm( 4578):   at android.os.Looper.loop(Looper.java:130)
I/dalvikvm( 4578):   at android.os.HandlerThread.run(HandlerThread.java:60)
I/dalvikvm( 4578):
W/dalvikvm( 4578): threadid=13: thread exiting with uncaught exception (group=0x2aac4560)
E/AndroidRuntime( 4578): *** FATAL EXCEPTION IN SYSTEM PROCESS: PackageManager
E/AndroidRuntime( 4578): java.lang.OutOfMemoryError
although I have no idea what the underlying issue or fix is other than to see if stayboogy has a suggestion for you.
Let me know re. which area to move your thread to.
Thanks!
