Hello i am very frustrated by the fact that i have been unable to root my zte warp (i know its posted in other threads, please let me explain). i am a NOOB, everytime i go and find root software it dosent work and appearently i need like special drivers? i am running windows 7 on my computer
basically what im asking is
1. please give me everything on how to start the rooting process (from the begining, that means first install, blah blah drivers then do this then etc...)
2.step by step instruction
3.when you say drivers does it mean when i plug my phone into the computer and it says "would you like to install software", would that be considered the drivers you keep mentioning to
4. how long will it take
i understand you have to do this clockworkmod thing, but when i downloaded that ultimate warp drive file and i started the rooting i would follow all instructions and i would get past the first 2 questions then it says
"first we will install clockworkmod recovery.
rebooting into bootloader...
* daemon not running. starting it now on port 5037*
*daemon started successfully
flashing clockworkmod rocovery...
< waiting for device >"
then my phone reboots and the little android thing stays on the screen and never leaves i need some help figuring this out..is this correct and im just impatient or what?? btw i waited about 25-30 min for it to work and usb debugging and everything is turned on
very sorry for this i would much appericiate it if you could answer my post!
