Root need help, i think i hard bricked
im stuck with a blank phone that that ask for a qhsusb_dload driver when i plug it in to my winows pc. does anyone know where i can get this driver? is there a way to unbrick without having to jtag my phone?
Try Using A Different Cable with unbrick tutorial.. Same thing happen to me...my computer wouldnt recognize my spirit...i hope i helped out...
i thought same thing happened to me than i used the oem cable with a different laptop after installing 3.8.1 drivers. hold volume up and volume down and plug in the usb into your phone than wait for download mode to come up before you let go.
His phone isn't "Dead". You have to simply get another computer, along with different cables. Then try numerous of times to get into download mode. Same thing happened to me, you'll get it!
Its cool thank you guys for your help, i just went up to metro to buy a new spirit and they swapped me for a brand new one without question of what happened to it. my day went from horrible to happy real quick. Good thing i made a EXT backup :car:
http://androidforums.com/showthread.php?p=5815047
For future reference, this is supposed to get you out of QHUSB mode. Not sure if it works though. Must have qpst installed, the qhusb driver and run emmcsomething.exe
I don't have instructions on this yet and probably won't until I figure out exactly how it works..
Just Google for the 32-bit driver.
Also for all of you saying to use my unbrick method: that doesn't work if it's booting to QHUSB.
Getting out of QHUSB mode - Android Forums
yea i was going to do that but it was a B trying to find the msm8960 qhsusb drivers and no one had the spirits bootloader lying around i could reflash
