Root Need Help Please
hanzsolo
Sorry if this is a newB question but I need some help please;
I rooted my nexus S and when I boot up holding the power and volume up button, it says LOCK STATE - UNLOCKED..
So I tried installing a custom ROM and and got the following error;
Installing update...
Welcome to NSCollab
Wiping Cache
Extracting System : CM 7
Cleaning System
Finalizing Installation
Flashing Kernel: Netarchy CFS
assert failed: write_raw_image("/tmp/boot.img","boot")
E:Error in /sdcard/NSCollab-1.0.22.zip
(Status 7)
Installation aborted
Any idea how I can fix this ??
Thanks so much
It sounds like you are trying to flash a rom that hasn't been completely downloaded. Have you tried redownloading the rom and flashing it again?
It also seems like quite a few people have been getting the status 7 error. Which i have never experienced so i might not be of much help. The best thing i can always recommend is to go to the Q&A section on XDA and ask there. Every problem i have ever had with rooting has been solved on XDA.
Update nevermind, looks like you already asked this question on the NScollab thread. Someone should definitely be able to help you out there.
Welcome to NSCollab
Wiping Cache
Cleaning System
(Status 7)
Thanks so much
This usually happens to me when I choose apply updated zip file instead of install from sd, make sure you choose install from sd from the rom manager.
